Bosch injector data.
  • Flat on my back
    • Jan 2007
    • 2449
    Would like to check the data on a set of injectors...0 280 156 095.
    Been on a site recently listed on here but the part no. wasn't shown.?
    Can someone help?
    Cheers.
    Carlos.
  • Audi Parts Guru
    • 1317
    Can someone help?
    Cheers.
    It's fitted to the Ford Focus, 173 bhp engine
    1, Resistance 14.5 ohms
    2, Flow rate 175.4 cc per min @ 2.7 bar fuel pressure
    3, Bosch EV 6.2L injector type
    Hope that helps
    • Flat on my back
      • Jan 2007
      • 2449
      Hmmmmmm...
      Not sure if that's going to help get to 200 hp in my 7A, unless the extra fuel pressure is the reason.
      Now where's that injector calculator gone...
      Thanks.
      Carlos.
      • Audi Parts Guru
        • 1317
        Thanks.
        Forget it, these are high resistance injectors and if I remember correctly, the 7A injectors are low resistance
        Also, increasing the fuel pressure will make very little difference, if any, in terms of fuel flow rates
        • spink
          • 4382
          that's right but if you bypass the injector pack in the scuttle panel you can used high impedance injectors.
          • Audi Parts Guru
            • 1317
            Maybe so, but the 7A injectors are made by Hitachi, and lets just say that they're not exactly the best injector manufacturer in the world
            Give me a set of Bosch injectors any day
            • Flat on my back
              • Jan 2007
              • 2449
              Bypassed already with a set of Bosch .jectors fitted.
              Will have to get the no. tonite and see wot you think.
              Carlos.
              • Flat on my back
                • Jan 2007
                • 2449
                Right...
                Wot i have fitted now is a set of supposably equivalent/slightly better bosch .jectors part no. 0 280 155 931.
                Found some data on these but does someone have a pdf data sheet on these 2 i mentioned so i can compare and contrast to find the best one?
                Mr 'Guru' wot does one think of these 2?
                Carlos.
                • Audi Parts Guru
                  • 1317
                  Forget it, these are fitted to a great big Holden 5.7 litre V8 producing 300 bhp
                  Unfortunately I don't have the full specs on these injectors
                  • Flat on my back
                    • Jan 2007
                    • 2449
                    Jesh...
                    Ones not a happy bunny now...both sets were purchased from a reputable source, the
                    ...931 as a replacement Hitachi set and the ...095 as an upgrade to go with the v6 maf mod on the 7A engine...arje...
                    Any idea on a replacement for these Hitacky sprinkler jobs...
                    Carlos.
                    • Audi Parts Guru
                      • 1317
                      Might cost you a bit more but i'm sure it'll be worth it
                      • 20Vcqdriver
                        • 829
                        Injectors
                        Carl,
                        The upgraded injectors for the MAF were specced up by 034EFi and worked great in my set up. Whats the issue with them?! They may also be for a holden but from memory that uses a higher fuel pressure which does make a big difference!
                        1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
                        2004 A4 2.5TDi convertible, re-mapped to 180bhp
                        2011 A5 sportback 3TDi-Backbox delete, remap
