Badly...
The two bucket tappets, which look outwardly alike, may only in the motor vehicle types assigned for it blocked become! They are exchangeable in no case!
Resembles geometrical dimension however not exchangeably, because:
• different dropping times of the hydraulic element (HTE)
• Dosage of the quantity of oil
• other specifications of the oil
• other surface finish of the Cup ground (e.g. case-hardened, nitrated, etc. phosphatizes)
• Kind of the tappet (labyrinth, discharge-secured or bucket tappets with interior detour)
• different spring action of the check valve
• different Ventilhübe of the hydraulic Element (HTE) (way in mm) Possible consequences during neglect:
• increased mass forces
• Noises in the valve impulse
• higher friction and material wear
• Material overloading
• higher pollutant output and fuel consumption
• Damage to the engine!
