Chaps,
Im planning to take a look to find out what the problem is at the weekend and wanted to know if you have any suggestions.
At the moment when cruising along it feels like the engine misses the odd beat very slightly you can feel car hold back for just 1/2 a sec when driving along every now and again.
Then when it comes onto boost it coughs and splutters and generally holds back and wants to kangaroo.
I changed the engine mount on drivers side a month ago so will check the Lamda is connected up properly. MAF connections and the intake pipe are connected properly.
The coils and leads were changes last year and the plugs changed last year and currently running NGK's, but tempted to put some bosch back in to see if it helps.
Any other suggestions?
