What is the voltage the injectors are driven at?
Injector Driver Voltage
12V matey. The +ve feed is triggered by the fuel pump relay thru S24 or S28 from memory.
The ECU then provides a switched path to 0V for millisecond durations for each individual injector.
I'm closer to building my fuel test gizmo after some tests with the B-Box last weekend. Wassup anyway ?
PaulPaul Nugent
I just want to add a function to the EGT display to monitor how hard the injectors are working. I can switch it to monitor one injector, and show on the display, a percentage of the injector duty cycle.
Just making sure it wasn't a low regulated voltage it was using - thanks.S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
Originally posted by Doug_RS2I just want to add a function to the EGT display to monitor how hard the injectors are working. I can switch it to monitor one injector, and show on the display, a percentage of the injector duty cycle.
A 'fang' display - neato !Paul Nugent
