Injector Driver Voltage
  • Doug_RS2
    • 3847
    What is the voltage the injectors are driven at?
    12V matey. The +ve feed is triggered by the fuel pump relay thru S24 or S28 from memory.
    The ECU then provides a switched path to 0V for millisecond durations for each individual injector.
    I'm closer to building my fuel test gizmo after some tests with the B-Box last weekend. Wassup anyway ?
    Paul
    • Doug_RS2
      • 3847
      I just want to add a function to the EGT display to monitor how hard the injectors are working. I can switch it to monitor one injector, and show on the display, a percentage of the injector duty cycle.
      Just making sure it wasn't a low regulated voltage it was using - thanks.
        A 'fang' display - neato !
