Hi guys..
I been working on the car alot and I was thinking about a potential solution for an oil cooler. I have the stock aby setup but the oil cooler is really in bad shape. I have two main radiators, ones a Nissen with metal end tanks that I picked up today at the junkyard for $50 and is in like new condition. The other is an oem unit. I figure at some point I will take the oem one to this place called luther welding and have them make me a custom alluminum one. But in the process of all this radiator thinking I thought what am I going to do with the aux radiator? Well Mines the shorter one, than stock s2s. I can do a 180 with it and mount it backwards putting the inlet and outlet on the air box side of the car, shorten the pipes and add weld on fitting.
But could it handle the pressure of the oil???? I Think it would be in a perfect spot for getting air. Plus the fact that it's new and hasn't seen coolant and since I spent the money getting it I mind as well put it to use if possible.
That is thy question.
Thanks
Josh
Thanks
Josh
