I have arp's in my engine. i torqued to the recommended setting.
in the 16v engines this was usually upped by about 10-15lbsft.
i used the standard arp rating and the gasket is seeping ever so slightly and maybe the head is lifting a little under high load.
whats the findings of other arp users. do you go above the recommended.
i recollect an issue with a raceport head on a mk1 fiesta Xr2 and a local expect said ignore and go to "FT".
My stud kit states 85Ft/lb but I used 65 as stated on here many times. I have since upped to 75 on a re-torque and it is improved slightly but I think I will have to goto 85 ft/lb. I am using the sport q washers. (My engine has done 4k since rebuild also
