what pressure? what rpm?
  • aronmatic2
    • 2129
    • Country: Hungary
    i need you guys experience.
    i am not satisfied with my car. 2.2 engine gt2876r with .82ar
    i have 2 bar boost on 4400rpm. i think its late.
    my previous car was 2.5 stroker with gt3540r with .63ar.
    boosted 2bar on 3500rpm.
    what you guys experience?
    Real carbon parts for S2 and RS2. Check Carbondesign on facebook
    I'd have thought the .63 would be better suited to that turbo, it's virtually identical in spec to the 3071r
      Got a compressor map for that 2876 ?
      The larger A/R numbers always deliver higher up the rev/flow range and you are running it with 2226cc so I would expect it to be worse for low-mid end performance than a 2.5 stroker on a similar sized turbo with smaller A/R.
      • aronmatic2
        • 2129
        • Country: Hungary
        the 2.5 had a much bigger turbo.
        • A80Avant
          • 10873
          • Country: Greece
          i wouldnt expect the 28 piece from the hotside to create such a lag.
          on which gears do you get the 4500? on the 2nd and 3d or the higher gears?
          • +500hp
            • Dec 2004
            • 51
            That is late!
            With 67mm impeler turbo and 2.2L you can have 2bar arround 4000rpm.
            Are you sure you do not have boost leak, cam timing right etc...?
              Paul bookmark this page http://s4wiki.com/wiki/Garrett_compressor_maps
              The 2876 is called the 2540r in old garrett numbering see http://www.s2forum.com/forum/showpos...1&postcount=11
              • aronmatic2
                • 2129
                • Country: Hungary
                3rd gear: 4300-4400rpm=2bar
                4th gear: 3900-4000rpm=2bar
                Originally posted by +500hp
                That is late!
                no. i dont have any mechanic problem. i checked everything.
                i checked my older logs, from my green s2 with 2.2 gt30r .63ar
                almost the same.
                • GazzaG60
                  • 4133
                  different wastegate spring? is that one weak
                  valve lift maybe
                  • aronmatic2
                    • 2129
                    • Country: Hungary
                    valve lift maybe
                    i tryed a stronger one. nothing changed.
                    maybe not true the gt2876r has full boost on 3500rpm on 2.2 20vt.
                    • A80Avant
                      • 10873
                      • Country: Greece
                      wont be the first time rumors are not turning out to be true..
                      • Billman
                        • 4129
                        what are the dimensions of the compressor and turbine wheels on these turbos?
                        Go Holset or Go RS4
                          034 reckon full boost by 3000 on that turbo, something is wrong I'd say. .
                            Your confusing it with the 2871 which will have that boost profile.
                            This is the 2876r http://www.034motorsport.com/product...roducts_id=714
                            • aronmatic2
                              • 2129
                              • Country: Hungary
                              ok. but if the 2871 working on full boost at 3000rpm. my turbo has to do the same max 3500rpm.
