Oil pressure sender
  • URSIMPO
    • Jul 2008
    • 431
    Oil pressure sender
    Hi,
    Does anyone know where the oil pressure sender is on the AAN? My S6 is without one, whereas the urS4 does have one. Not sure why Audi omitted it
    Thanks in advance
  • valjo
    • 1110
    • Country: Latvia
    Originally posted by URSIMPO
    Hi,
    Thanks in advance
    it is under wather rail
    Audi Coupe S2 1993
    Audi V8 4.2 1993
    Audi cabrio 1998
    • URSIMPO
      • Jul 2008
      • 431
      Where is the wather rail. Apolgies for my lack of knowledge
      • johne
        • Apr 2007
        • 1405
        Valjo means under the water rail, i.e. under the inlet manifold, under the water pipe returning along side the block from the heater and behind the water pump.
        John
          Hi,
          Does anyone know where the oil pressure sender is on the AAN? My S6 is without one, whereas the urS4 does have one. Not sure why Audi omitted it Thanks in advance
          Have a look at this post, it shows where the oil pressure sender and the oil pressure switches are located on an Ur S4 AAN. The Ur S6 does NOT have an oil pressure gauge so there is NO oil pressure sender. (I don't know why Audi dropped it either):
          http://forums.audiworld.com/s4s6/msgs/148742.phtml
          • kwlw
            • Sep 2004
            • 1025
            • Country: Lithuania
            BUT there's threaded bung in the place it should be. And you can easily put aftermarket or original sender (M10x1) in to the hole, make some two wire non sophisticated loom (usually comes with normal grade gauge, one wire is for pressure sender, other is for the gauge low pressure light) and have oil pressure display somewhere you like.
            Sau
