Valjo means under the water rail, i.e. under the inlet manifold, under the water pipe returning along side the block from the heater and behind the water pump.
Hi,
Does anyone know where the oil pressure sender is on the AAN? My S6 is without one, whereas the urS4 does have one. Not sure why Audi omitted it Thanks in advance
Have a look at this post, it shows where the oil pressure sender and the oil pressure switches are located on an Ur S4 AAN. The Ur S6 does NOT have an oil pressure gauge so there is NO oil pressure sender. (I don't know why Audi dropped it either):
BUT there's threaded bung in the place it should be. And you can easily put aftermarket or original sender (M10x1) in to the hole, make some two wire non sophisticated loom (usually comes with normal grade gauge, one wire is for pressure sender, other is for the gauge low pressure light) and have oil pressure display somewhere you like.
Sau
