Further to the thread below...
http://www.s2forum.com/forum/showthread.php?t=32889
Consider the attached to be definitive reference info for how boost control is acheived on the S2 and essential info on how the wastegate (WG) and wastegate frequency valve (WGFV) work.
It includes info on the factory setup and some alternative layouts for consideration.
In time, I'll add some info on the throttle bypass valve (TBV) as well as consideration for atmospheric dump valves.
