bosch "others" greens injectors
This is a sticky topic.
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    #31
    someone knows wich it is the maximun fuel rail pressure for use the Original RS2 dark green injectors with hight reliability?? 5bar maybe??
    • M_GORDON
      • Oct 2008
      • 1295
      • Home: Isle of Man Current: Vatican City State
      #32
      Perhaps
      maybe
      photobucket SUCKS
        Why would you run at 5 bar? You need a pump that's going to pump at 5 bar + boost pressure and that means a motorsport 10 bar pump
        • Jonas_R
          • 3780
          • Country: Denmark
          #34
          I would think he wants more fuel from the injectors
          Sleeper S2 Avant +450
          A6 Avant 2.7t Stage 3
          Audi S2 Coupe RS2'ed
            Yes but I'm pointing out unless you got a motorsport pump you can't do it as the pump wont flow at the elevated fuel pressure on boost. A stock 044 can't flow at those level.
            Buy bigger injectors!
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #36
              hey i am only asking about the max pressure that can be used in the RS2 injectors.
              of course i dont want 5bar FPR....but i would like to know the question about i am asking.
              it is only because now with my current injectors ,7A FPR and RS2 fuel pump relayed to 14volts it is enough for my setup. but because i have AFR numbers in WOT like 12 - 12´3 it would be fun test with a adjustable fuel pressure regulator with a little more pressure in the fuel rail if the AFR numbers could go richer in WOT like 11´8 -12 only this...
              i had used the 440cc/3bar apple green injectors and the AFR numbers in WOT were 10´2 ... too rich
              thanks for answer Jonas and Jamo
              • Jonas_R
                • 3780
                • Country: Denmark
                #37
                I guess you could buy an adjustable FPR and try to set the fuel pressure up like 0.2 bar.
                • Rocco
                  • Aug 2007
                  • 6393
                  • Country: Spain
                  #38
                  thanks Jonas,and then...any suggestion?? 034 Motorsport sells somes...but surelly any aftermarket could helps if it can be used for more than 4 bar
                  • Micky B
                    • Sep 2006
                    • 77
                    • Country: Hungary
                    #39
                    You can mod your factory fpr.
                    Just put it in a jaw and press it with a 1/2" bit a little.
                    So you tension the spring a little more inside...
                    It is a one way mod
                    But it is cheap and is ok up to 0,5bar extra.
                    Does anyone know anything about this injector:
                    b 280 709 756/4 bosch grey
                    (103 016 060)
                    M
                    www.bauerracing.hu
                    • Neacail
                      • Jul 2016
                      • 3
                      Nobody using the 0280155968 from Volvo application?
