Hi all
I am in the process of changing my rods for some scat rods I have removed the subframe & all the fixing from the sump & double check that they are all removed.
The problem i have is the back of the sump seems to still be fixed to the gear box end i have levered it at the front & it seal is broken but it is still hang on at the back.
I had to remove the heads of two bolts, the sump is free and moving in the area of the bolts with out heads, but they will stop the sump moving forward.
Are there any pins or any thing other that could be holding if firm at that end.
Dose anyone have a picture of a RS2 sump off that would show me what could be holding it or what it looks like.
Regards Jade
Regards Jade
