Full boost only in 6th gear
  • bertman
    • Apr 2007
    • 1173
    • Current: United Kingdom
    The old girl only seems to getting near to 1.4 bar (homefries norm) in 6th gear only. 3rd,4th and 5th gear I am not really seeing anything above a crappy 1.24 bar.
    Have tested for boost leaks and none have been found,but surely if it were a leak it wouldn't go up to nearly 1.4 bar
    Thinking it must be an electrical gremlin...maybe
    Any ideas what could be causing this problemo???
    Rob
    Ragussa green avant RS2+ spec
    Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
    Audi coupe gt-slow as hell but loads of character-sold
  • Rocco
    • Aug 2007
    • 6393
    • Country: Spain
    in my car the maximun full boost always was in the last gear.....
    • bertman
      • Apr 2007
      • 1173
      From a previous thread I asked what the in-gear boost figures were for homefries,and the general rule of thumb was that you should see 1.4 bar in all gears except 1st and 2nd
      Rob
      • A80Avant
        • 10873
        • Country: Greece
        lots of things to test.
        first fault codes,
        then:
        MAF,lamda,N75,leaky DV, a leak on the vaccum hoses.
        When you pressure tested,what part of the system did you test?
        • bertman
          • Apr 2007
          • 1173
          All of the parts are new,pressure tested the boost hoses and found no leaks.Haven't tested the vacuum hoses yet.I take it you take the metal bung out and let the air through the inlet manifold to do that?
          A leak would affect the boost in all gears.....wouldn't it
          Rob
          • A80Avant
            • 10873
            • Country: Greece
            if the leak is small it can be very mysterious.High gears produce pressure more easily so that you can actually see the boost you are expecting,but that doesnt happen with the rest of the gears.
            vaccum hoses are best visualised,and probably take each end and blow into it.If you just put air in the inlet manifold,air will leak through the cyl.head and you wont know where it is escaping from.
            Also you could be loosing air from the intercooler if you havent tested that as well.
            • bertman
              • Apr 2007
              • 1173
              That makes sense with the car producing higher boost,but surely with the "fries" it should produce the same amount of boost in the gears mentioned.
              Blooming cars
              Rob
              • A80Avant
                • 10873
                • Country: Greece
                yes that is when there are no leaks!
                but when there are,its a different story!
                do you hear any hissing sound in the car as well?
                • bertman
                  • Apr 2007
                  • 1173
                  No obvious hissing sound at least
                  Rob
                  • Smiley
                    • Jun 2005
                    • 329
                    Have you done a pressure test on the wastegate (diaphragm)?
                    '93 Audi S2 Avant panthero black, 412.000km
                    '94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
                    '93 Audi S4 C4 Avant, 260Tkm
                    '88 Audi 100 Avant turbo 44Q
                    '84 Audi 80 quattro tornado red
                    • GazzaG60
                      • 4133
                      id say gate too. or exhaust leak. same thing different places.
                      6th produces more load and therefore gases so spool should be quicker and boost at its highest attainable.
                      • bertman
                        • Apr 2007
                        • 1173
                        Erm the answer to that one is ..no I haven't.Could it worth replacing that with funds from my measly christmas bonus.
                        Would a slightly leaky wastegate diaphram cause these symptons
                        Rob
                          No, a leaky wastegate diaphragm will likely give more boost not less IMHO. A bad WGFV might be the cause though, worth replaciing if its not that new. I usually leave the inlet tube connected and boost test to about 1 Bar, some pressure will leak past the rings and valves but you'll hear if any of the small hoses are leaking, still need to block off the PCV pipe at the MAF hose though.
                          • s2_bo
                            • Oct 2005
                            • 6067
                            Go easy on it if your only seeing full boost in top gear.
                            If you do have a small leak and its only managing to make full boost in 6th then you could be wringing the turbos neck as its trying to make your boost. Might be pushing it up to the equivalent to 2 bar.
                            my RS2 was like this for a while. Turned out to be a sneaky boost leak and now its fine
                            Check the Vac lines at the back of the inlet manifold, just blow in then like A80Avant suggested. they should all hold pressure.
                            Good luck.
                            P.s. if you do what John suggested you need to have a fully intact PCV system too or air will escape there as soon as you put any pressure past the pistons.
                            91 S2 coupé - RIP
                            98 S8 - Luxury barge
                            • ryster
                              • Sep 2007
                              • 224
                              hi there thats the pcv system cheers
