I have the kit as detailed above and in the link below fitted to my 93' ABY Avant
Im haveing some issues with the car when on boost, it seems to spool up ok but sometimes (3 outa 4 times) it doesnt boost smoothly, it like hesitates several times, with some like violant jerking...
its been suggested in a previous post that the coils are usually the culprite, my question is; the kit fitted to my car (as above) doesnt use the POS it has a seperate loom and what they discribe a custom modified (06B 905 115R) A4 coil packs.
if ive got a problem with one, how do i identify which it is, and once i can find it what do i replace it with if the coil has been "custom modified"
alternatively, what else could be causing this intermittant problem (coil kit is only about 18 months old) I had a boost test done recently at QST with no problems and it doesnt feel any slower when its not doing it, which leads me to beleive its eletrical?
Ive been to Cuba for the past to weeks and am dying to get back in the S2, so help would be greatly appreciated...
cheers,
Keith
cheers,
Keith
