What's the max power by RS2 turbo?
  • MarT2
    • 175
    • Country: Spain
    Hi all!
    I would mount a full RS2 conversion (injectors, fpr, ecu, turbo, cam pulley, camshafts, etc) and mount a wagner EM, IC kit and reverse IM, ADU MRC high boost chips, and full 3"exhaust without cat.
    What is the maximum power and torque that I can predict?
    Can the RS2 mechanical resist this power and torque?
    Thanks!
  • URSIMPO
    • Jul 2008
    • 431
    The max hp of the rs2 turbo is circa 380hp
    • M_GORDON
      • Oct 2008
      • 1295
      • Home: Isle of Man Current: Vatican City State
      well, and if I have only all of RS2...my power going to only around 360, not?
      photobucket SUCKS
      • A80Avant
        • 10873
        • Country: Greece
        if you do all that get at least a 3071R turbo
          The RS2 turbo can make 400 bhp at 2.0 bar however it's turbo life will be drastically reduced.
            Flowed cylinder head is often overlooked. That will boost whatever power you get, as will water injection.
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              i had 2.0bar boost with all my specs..
              it will be awesome if i managed 400whp
              • Prophet_dlx
                • Nov 2007
                • 262
                • Country: Luxembourg
                And what happend to your engine?
                RCN
                  400 crank not wheel power
                  • GazzaG60
                    • 4133
                    flowing the cylinder head has the same effect as raising the boost on turbo life. the turbo has to work harder to make x boost.
                    pushing a turbo to the max has one advantage. high torque.
                    • MarT2
                      • 175
                      • Country: Spain
                      The max power I could obtain, without reduce the life of my turbo is around 380cv?
                      • prosty
                        • Jun 2005
                        • 1114
                        350-360 is about the right amount of power if the turbo life is to be ~unaffected, but several ppl run ~370-380 hp for a few years without any troubles, it has to do with many things, oil, condition of the turbo before turning up the boost / power etc.
                        A good flowing em, and a ported head should be able to get the rs2 turbo at about 400 crank hp, but I would go with a better turbo for that power level, seeing that the rs2 turbo doensn't want to hold boost / deliever power after 6000 rpm. 3071 after Rs2 turbo, after that GT35R or GT40R..
                        2004 9-5 aero
                        2009 Subaru Legacy Diesel
                        1994 Toyota Supra Eurospec 6-spd LHD
                        3-4 Audis in parts
                          Yeh I reckon that's a good value, the MRC high boost RS2 chips boost to 1.9 bar
                          Be interesting if S2avant gets his car on dyno to see the official bhp figure.
                          • Rocco
                            • Aug 2007
                            • 6393
                            • Country: Spain
                            maybe 1,7 bar it´s the most safer boosting level
                            Mart2 mirate bien las compresiones de tus cilindros antes de darle mucha caña y sobre todo asegurate de que todo el sistema de inyeccion de gasolina va perfecto
                            you have to test the compression levels in all cylinders before go hard with the RS2 turbo,and test every fuel inyection parts
                              Well it was 360 on a standard chipset so should produce rather good figures on the high boost ones.
