I've just discovered there are different sizes of wastegate on the S2 and I wonder if there are different part nos for the 3B and ABY Wastegates ( I was aware that the springs may be set differently but not of any other mechanical differences..)
This was discovered when my GT3071r was fitted and I was getting boost creep at high RPMs. We thought there might be a fault with the WG but actually it turns out that not only was it not opening fully due to poor machining but the valve was smaller than in the replacement one. It was obviously seriously impeding wastegate flow.
Anyone fitting a larger turbo and 3" system needs to be aware of this to avoid having to do the job twice.
No wonder you were getting boost creep. IIRC you had boost trouble with the RS2 setup too.
