bit of history..
driving the car a couple of months ago, very occasionally i would get a hessitation when the car came onto boost (WOT), then it would clear and wouldnt do it again for a couple of journeys, this has been getting more frequent over the past month, to the point where it would do it 2-3 out of 4 times i put my foot down. I then had the main radiator crack on me, and have a devil of a job trying to get the Hella one from GSF instead of paying Audi £220+VAT. Got the radiator finally friday, and fitted it yesterday (3 hours to remove and refit.. was quiet chuffed) At the same time i bought new Bosch F5DPOR plugs and fitted them (incase the hessitation was down to something silly like the plugs) toop it for a spin earlier today, same problem as befor, and now it does it every time you put your foot down (WOT) in every gear, seems to come on at about 3k rpm.
The problem itself is @3k+ rpm (ish) and its like theres a flutter on the boost, its all jerky, not smooth at all
Im running the Apikol Ignition system that uses the 1.8T coils (06B 905 115R) and have the MTM remap from QST
I had a boost leak test done a few months back, and that was fine, but that was a few months back.
to me it feels a bit more like something opening and closing and loosing boost.
It was suggested to me that it could be the a dodgy coil, but it feels more like a mechanical problem, is there anyway i can test the 1.8T coils used in this ignition system?
Could it be something to do with the boost control (WGFV)? what does the WGFV do? and how can i check if its functioning correctly?
can i disconnect it and see if theres any improvement with mechanical boost? if so what do i disconnect? where is the WGFV, whats it look like?
any other suggestions?
many thanks in advance
Keith
Keith
, may be a bit harsh.
