problems with boost @3k rpm + fluttering on/off/on..
right....
problem seems to be solved 8)
I replaced the WG Diaphragm, and that made no difference at all! and what a barstuard of a job! trying to get the 11mm nut undone!
so, thought nows the time to try the coils, started at no.1 and worked my way back, doing 200-300 meters, just long enough to boost in 2nd did this 5 times, and on no.5 it was back to normal!
So the problem has appeared to have gone away.
next question, i ordered the new 710N DV from VW earlier, will be in first thing in the morning, should i change it? is there any advantege over the standard one?
well, i pulled the valve up as far as it would come, managed to shred the old diaphragm by tryin to undo the nut, i then wrapped 2 nice big snap-on screw drives with electrical tape to make them a little softer and more grippy, then gently tapped them in the gap, then just undid the nut. to refit it i did it as tight as i could by holding it and used thread lock...
excellent did not think of that at the time, you must have used a heap of electrical tape
, good effort glad to hear you got it done.
My diaphragm looked like the original one it fell apart in my hands when i took it off.
Keith where about's are you from? you're certainly not a yank they way you talk about "Steelers"
Good to hear another S2 has got full boost again
cheers
JohnComment
Im from tonbridge in kentexcellent did not think of that at the time, you must have used a heap of electrical tape
cheers
John
but, the way you described the problem just sound like what i had......
, what did you do to undo the bolt? what was your trick?
