@Jamo - thats a good idea, and I know where you are coming from but at idle the ECU is in closed loop mode with lamdba feedback on mixture so it modulates round stohic mixture as quickly as a healthy probe will allow.
The only way to spoof the lambda probe is with a good WB-O2 probe/module... Like TechEdge, LC-1, Zeitronix - you can safely setup for a lean setup so that the ECU modulates happily and error free around a less rich mixture.
