Any interest in switchable chipsets ?
    @Jamo - thats a good idea, and I know where you are coming from but at idle the ECU is in closed loop mode with lamdba feedback on mixture so it modulates round stohic mixture as quickly as a healthy probe will allow.
    The only way to spoof the lambda probe is with a good WB-O2 probe/module... Like TechEdge, LC-1, Zeitronix - you can safely setup for a lean setup so that the ECU modulates happily and error free around a less rich mixture.
      @Bo - the sport/economy mode is just one suggestion... Could be two 'sport' modes - one being more aggressive than the other and requires 99RON fuel and water injection to run properly. Think of it has having a factory or generic chipset in one bank and something customised in the other... Or one with 'his/her' modes for those that have (in)sufficient trust of their spousal driving capabilities on the beloved car.
      Selecting between two banks will require one wire, extended from ECU internals, to be left open circuit or pulled to ground. Can't do much easier than that for a 1-bit binary bank selector !
      • Sonic
        • Jul 2006
        • 5514
        When i drove mine with the N75 disconnected i was quite impressed that even the mechanical boost alone allowed you to dominate most problems.
        Am i right in thinking homefries is 1.3-1.4 bar? If thats that case, 0.8 bar sounds sounds a good number, unless you want a super economic mode - but them you may as well buy a diesel.
        The best ive had was following Stu's lupo on the way to harrogate. First i started by dropping it into the higher gears early, then accelerating slowly instead of just mashing the right foot. Then i started avoiding the brake pedal as much as possible and trying not to brake at round abouts. Finally i started dipping the clutch and dropping it into neutral, coasting downhill.... resulted in an average of about 40mpg - a figure ive only ever seen in my clio
        S2Forum.com Administrator
        • shark_90
          • 1475
          Ah ha! There, my friend, you have made an error! A modern engine won't actually use any fuel if you are off the accelerator and the car is in gear, however if you coast the engine is using fuel to idle.
          Strange but true
          (BTW my S2 average is 16mpg and I've had 60mpg our of the Bora a few times )
          1994 Audi S2 Avant - in pieces
          2006 Skoda Octavia vRS 2.0TFSi - goes fast
          1985 Audi 90 quattro - is wet
          Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
          • Sonic
            • Jul 2006
            • 5514
            #20
            Strange but true
            Thats more modern cars though like the new funky bmw's, not the s2 right?
            • bernsaudi
              • Feb 2007
              • 592
              I'll have one to swap between lpg and petrol please, to advance my timing and compensate for the MAF reading whilst pumping my lpg in downstream of the MAF
                S2 should be able to do it as well as it does measure engine load.
                S2central?
                • HPmuirt
                  S2Forum April Fool
                  • Apr 2005
                  • 3014
                  #23
                  The really obvious way to go sport vs economy is have the economy chip setup for very conservative boost levels - like 0.8bar or something - so you have some oomf for overtaking.
                  I for one love this idea as it is just too painful to drive economically, so actually switching it into that mode would be great.
                  I have one dumb ar$ed question though and two standard questions: -
                  1. I am assuming we could switch maps on the fly so that we can hit the sport button and get full beans whenever some chimp in a ricer needs a seeing to? :mischeif:
                  2. Wassit gonna cost? (I already have the homefries map )
                  3. When can I have one? (and don't do the German manifold/IC bloke trick of saying 45 days over and over again )
                  Cheers n
                  Si
                  Subtle mods here and there
                  2011 A5 3.0 TDi - Lava Grey
                    #24
                    1. The mode should be changeable anytime on the fly - to be confirmed
                    2. Dunno yet for sure - depends if I outsource some tidy hardware mod, create my own or some other less elegant looking hack. Guess GBP50-100 ballpark.
                    3. You can be a Beta tester if you like. Lets say Easter timeline - don't want to commit much earlier than that, but you never know... I'll want to do some sanity testing of my own before I let this loose.
                    • Sonic
                      • Jul 2006
                      • 5514
                      #25
                      The on-the-fly change sounds a bit dodgy, but you'll know whether its possible Paul.
                      Am i right in thinking the s2 ECU "learns" the more you drive it? How would swapping the map regularly impact upon this or would it be able to store information for each map individually?
                      I like the idea of having my homefries for everyday use and then a "ring map" designed to work with 100ron jungle juice you get over on the continent
                      • Keeper of The Kitten
                        • Dec 2003
                        • 2317
                        I just read through the whole thread to see if someone had asked about on-the-fly switching, Si beat me to it - I am liking the sounds of this idea and I will be needing something one day when my car finally looks like something other than a pile of parts.
                        Martin Cutting
                          #27
                          @Sonic - that question about learning is the only unknown at this point. Well - I'll rephrase that - I do know the ECU is only aware of one chipset and its a hack to fake switchable use of two, so there is a chance that 'adaptation errors' could be raised by the ECU if there is a large step between the two modes when changed on the fly. At worst you would get fault codes, but actually they need to be sufficiently persistent to register as a fault so I dunno - again its why I don't want to have unlimited options and unknowns here.
                          For people like yourself wanting a generic map plus a custom/enhanced map on a switchable setup I'll need to think about pricing carefully.
                          I think the original idea of sport vs economy modes is generic enough that its in GBP50-100 territory, for existing homefry users... But its going to be more to cover enhanced/custom chips for individual users wanting a switchable setup. I'm very aware, especially in this climate, that their is a natural limit on what people think a tweak like this is worth.
                            #28
                            Seeing as this thread is getting more immediate attention & interest than I had imagined, I'll cook the hack into my spare ECU when it returns from duty.
                            I'll make mine switchable between the normal generic homefry and a more aggressive / winter friendly one that has been creating smiles recently. I'll run that for a while with plenty of 'on the fly' changes and let you know... I have a MIL bulb wired into my cluster so I will see any fault codes immediately.
                            I'll need to test out an economy chipset as well then - enter the new toys for real-time mapping and AFR checks, but that's another matter entirely.
                            • HPmuirt
                              S2Forum April Fool
                              • Apr 2005
                              • 3014
                              #29
                              Thanks for the answers...sounds good so far
                              I have a spare ECU and would ideally like an economy mode and fries mode. I also have your MIL lamp mod fitted so I may well be a good Beta tester for you
                              Cheers n
                              Si
                              P.S. Are you also suggesting that there is a better fries available?
                                #30
                                ALways reading between the lines aren't you ?
                                But in short - YES - there is a better fry up in Beta now for ABY. The clue is that it likes the wintertime;-) More info when I get more hard data and I'll probably wait for some AFR checks before it goes further... You might be able to persuade me to let you have a taste - while the air still has the artic chill.
                                Feel the fire !
