Hi guys...
i know its not an S2 but recently got a 2.3 10v coupe '93 that has some slight running issues. Tried looking for other coupe forums but no joys.
1, Car sometimes just turns and turns and doesnt fire. Wait 2 secs and try again and it fires up! Then it idles lumpy but occasionaly has a hunt, about 200 rpm, nothing terrible.
2, When approaching a juntion whils engine is cold, it has stalled couple of times but mainly the revs drop to 2/300 rpm and after few secs it picks up and revs around 1k rpm (idles currently at 950rpm)
3, where is the cold start valve and idle control valve?
I've replaced plugs, leads, dizzy cap and rotor and no difference. I removed air intake pipe and there was alot of grime around the twin intake butterflies. Presumably oil from the crankcase breather?? As the breather pipe joins into air intake pipe just before the butterflies on the TB.
Thanks for any help in advance.
