Is an engine rebuild necessary at 156k?
    A mate's Cossie was nailed at well under 100k. Still went well tho
    • 20Vcqdriver
      • 829
      Just run in
      Fitted a 103K miles 3B into mine last year and removed the head to change oil seals and exhaust guides, but the bores had virtually no wear at all.
      A refurbed head would be the max that would be required and even then only if you're doing an engine swap anyway and wanted to check everything out. I fitted the metal gasket at the same time so not expecting to be touching mine again for several years...make that decades as I am limited to 3000miles a year!!! He has obviously never driven anything but poxy Corsa's or Peugeot's.
      1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
      • k.alle
        • Feb 2008
        • 801
        Originally posted by KaraK
        hey! I've had two scoobys at ~ 130k miles and both engines were solid as a rock!
        Easy there tiger!
        Don't be offended, I was just having a laugh :mischeif:
        Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
        http://www.garaget.org/?car=52877
        • wez 47
          • Oct 2008
          • 47
          i agree;
          I'd have to agree with pretty much what everyone else has said above, my s2 3b has done 180k, and is sweet as a nut, i will soon be rebuilding mine however only because i'm tuning the motor in the quest for more ponnies he he!, cheers wez.
          • s2driveruk
            • 12696
            yup 186k on mine and not been opened up yet, i think the gasket on mine is a metal one anyway as it was a very late 3b so other than v/stem oil seals i can't see it needing more....all key sensors and seals were replaced last summer and most of those only as it was out of the car so access was good.
            1992 3b S2 Coupe
            • Sonic
              • Jul 2006
              • 5514
              #21
              Shame the chassis wasn't when you put one of them through a dry stone wall
              S2Forum.com Administrator
              • Acidburn
                • 13459
                don't worry its gone to a better place now
                it won't be chased and beaten by all them nasty people over at scooby slayers
                http://www.scoobyslayers.net/ (its bad when there is a site dedicated to that )
                • philKS2
                  • Sep 2006
                  • 370
                  My S2's on 149k and its the little things that are niggling... the engine itself is great
                  SOLD !
