I've just spent another drive home having to stop and restart the engine just to keep up with the rep mobiles. I was even blown away by an old A4 1.8T as I kangaroo'd down the road
Now I know everyone is going to shout fit your samcos, change your vac lines, it must be a boost leak, etc, etc. but please hear me out.
I'll be pulling the front end off in the next few weeks to fit the samcos, change the vac lines, fit catch tank and remove the PCV system, fit the IC mister, etc, etc so will hopefully remove any leaks but I want to make sure this problem is gone (at least for the forseeable future). I don't want to have to pull it apart again because of something I could of changed the first time.
It only happens when the ambient temp. is above 15 degrees and the engine is hot. To me this would appear to be something is expanding with the heat which is causing a leak. Any ideas?
Fingers are crossed that it isn't the intercooler. Is there a cheap and cheerful way to pressure test the IC on it's own? I already know there is a leak so there isn't much point testing the whole system.
Also can the IAT sensor or any other electrical components cause the overboost protection to kick in? Those that know me are aware that if needs be I will order anything and everything to fix my avant (it's not my money
) but I'd rather have an idea where to look instead of changing everything.
It's getting to the point where I'd consider removing the S2 badges and becoming one of the hum-drum sunday driving set until the cold weather comes round again.
Ben
) but I'd rather have an idea where to look instead of changing everything.It's getting to the point where I'd consider removing the S2 badges and becoming one of the hum-drum sunday driving set until the cold weather comes round again.
Ben
) I'll be uprating all the hose clamps and replacing all the vacuum hose (again) as well when I tear it apart.
