misfire
  • akojacko
    • 107
    misfire
    well just noticed a misfire whilst coming home last night . it only happens when accelerating hard and from about 4500 rpm. plug??? any ideas chaps. thanks.
    ako
  • s2driveruk
    • 12696
    air leak i'd guess, check the intake hoses and also that the jubilee clips are nice and tight....
    HTH,
    David
    1992 3b S2 Coupe
    • martinjs
      • 3205
      Are you still using those splitfire plugs ako?
      maybe worth trying some bosch ones.
      try cleaning your maf also.
      martin
      • akojacko
        • 107
        thanks guys. all hoses are ok. and yes i still have the splitfires in . was gonna change plugs at servive due in 500 miles . may have to book in now . lol. looked at changing plugs myself but how the hell do you get the cover off compleatly as so to get to all the plugs ??? ie wires etc ??......
        ako
        • Lee
          • 1512
          Remove the throttle damper first to remove the cover over the plugs: 2 torx screws. There is enough give in the wires to move the cover, complete with coilpacks to one side.
          My missfire was caused by the plug boots which go from the coilpacks to the plugs. My rocker cover gasket had gone, causing oil to seep into the recesses around the plugs causing the loss of spark. While you are checking shove some Bosch F5DPOR plugs in. Cheapest from GSF.
          Designun Limited....
          • akojacko
            • 107
            cheers will do . the only other thing i have done is change the fuel from optimax to bp ultimate . still on the 1st tank of this . wonder if this is causing me a problem ? anyone else uesd the bp stuff ? . ill fit some new bosche in before the service tho i think .
            ako
            • Lee
              • 1512
              My car doesn't like BP Ultimate. It works better on Optimax or Esso super.
              • Martynf
                • 1885
                I'll 2nd that, Optimax runs much sweeter than BP stuff.
                Martyn
                www.vagparts.com
                • dan_b
                  • Sep 2003
                  • 3670
                  I find BP Ultimate runs better in my car than Optimax. Go figure!
                  • Pete_RS2
                    • 800
                    Mine definitely prefers Optimax to BP. Just filled up with the Esso Super today and that seems OK too.
                    Now RS2'less
                    '99 VW Passat VR5 Sport
                      Are you guys serious about BP Ultimate - mine ran like a dog on that with a full tank of it at the end of the trip to GTi as I'd been nursing the car along with 95RON and new Samcos (which I didn't want to stress yet). The car doesn't run anything like as sweet as it did - I hardly use it much now and figured I had picked up a gremlin.
                      I'll do nothing, then get her back onto Optimax to see if I can spot a difference...
                      Paul
                      • sal_s2
                        • 1288
                        Mine seems to run fine on both optimax and bp ultimate, cant tell the difference between the two.
                        • pjeast73
                          • 144
                          I will never put BP Ultimate in mine again - mine was awful with full tank of that. Just filled up with Optimax - 6th gear now feels like 3rd on Ultimate. I'll be making the weekly trip slightly out of my way to the Shell station from now on. I think the Ultimate is responsible for my cut out at 4K - I'm hoping this may clear it. And last time I filled Ultimate it only started on 4 cylinders and I had to replace a coil. I'll stay well clear form now on.
                          • akojacko
                            • 107
                            reading the last few posts i think i will fill back up with optimax before fitting the plugs just to see if it is that that's causing the problem . will let you know the outcome.
                            ako
                            • jameswkr
                              • 538
                              See the other thread re plugs ! Audiman had a misfire. Changed back to F5DPORs ( from NGKs) and cured. Dont delay! James
