Hi all!
Since this is my first post on the forum I will start with introducing myself. My name is Eiríkur, I live in Iceland and have a 1992 Audi S4. I will put some pictures in Members cars sometime soon hopefully!
But then my question! I have a stroked engine, a AAN block with 95.5mm crank, 144mm H-beam rods and JE pistons, everything is blueprinted together, I have the stiffest motor mounts from 034 Motorsport but there are no vibrations from the engine!
I just got everything together and have just driven a little bit around in the low rpms, but now when I'm starting to think about using the gas pedal a little I first want to know how much rpm is a safe rpm on a stroker!?
I tried search and found this thread and the links in it:
But this is a rather old thread so I would like to know how things have been...
Is it ok to go to 7000-7500rpm or is 6500rpm the max!?
Hope you have some answers.
Thanks, Eiríkur B. Rúnarsson...
