Right i now have in my posession a brand new k27 turbo (boo, boo, hiss i know i know, old technology etc. . . . . I read it all, go for GT2871, GT3071r or GT3076R so iv saved the bother for all the kkk haters out there OK!).
I have managed to source the bigest k27 so flow should allow for a maximum of around 500bhp, here are the spec's.
14 blade compressor wheel with 49.1/80.7mm (RS2 is 12 blade 47.7/66.0mm for comparison, Right?)
11 blade Hot side wheel with 76.2/68.2mm
The cold side housing at the moment it a rather large split type #14 or #17 A/R! all of which is phenominaly large.
Im looking at purchasing a k27 #6 hot side housing and gatting my machine man to machine away what is needed to fit the large hot side wheel in, then for the moment i think with a large reduction in hot side housing A/R I think Im on a realistic BHP estimate of around 430-460bhp, im also estimating more or less full boost of 2-2.2 bar at around 3800-4000rpm
The reason im telling you this is what size K29 Compressor wheel is needed to take the turbo to the next level as it were (540-570bhp?) and would i be able to keep the k27 cold side housing (obviously machined) with the k29 compressor wheel or would a k28 or k29 be needed, and would I be realistic in going for a #7 k27 hot side husing in stead to maximise the flow?
Engine mods, suspension, brakes are all there, exept clutch i only have a spec stage 3 rated for 450bhp, this is the reason for the 2 stage thing with the turbo, (i want to change to an alcon unit but this is big money so it will have to wait a little longer as the spec has not even covered 5000 miles yet) the car has been off the road for over a year now and im having cravings for POWER, the 2.8td pajero just don't cut the mustard!
? Yes, turbine housing may be biggest, but it is compressor what matters for ponies.
. Fast spool, huge engine, loads of Nm at low rpm and no HP...
