My inlet fuel line got kinked and slighted crushed because the joiner to the fuel hose could not be undone and it bent the pipe in the process ( return was no problem )
How can I repair this?
Is there a way to make the pipe circular?
Is the fuel line solid from tank to engine bay?
Is there a way to replace the end section then would be safe?
How close to end was it? Has it still got the steel lines? you can cut off the end reswage if its not too far down the line. else it may be a good chance to change to copper?
Rob..
87 UR 20v ABY
97 S6 Avant
It's the bend at the very end of the line.
From what I can see the line is one piece from tank to bay
