Engine fuel line repair?
    My inlet fuel line got kinked and slighted crushed because the joiner to the fuel hose could not be undone and it bent the pipe in the process ( return was no problem )
    How can I repair this?
    Is there a way to make the pipe circular?
    Is the fuel line solid from tank to engine bay?
    Is there a way to replace the end section then would be safe?
  • GT500
    • Jun 2006
    • 2181
    How close to end was it? Has it still got the steel lines? you can cut off the end reswage if its not too far down the line. else it may be a good chance to change to copper?
    Rob..
    87 UR 20v ABY
    97 S6 Avant
      It's the bend at the very end of the line.
      From what I can see the line is one piece from tank to bay
      • stiglet
        • Aug 2007
        • 1264
        it goes to the filter, but to there it is one peice i think.
        You can always just cut the crimped bit off, then reflare it. Need a brake flaring kit though.
          I can cut it off and flare it but I'd be short, can copper pipe be used to replace the section that needs cutting out?
          • quattro
            • Dec 2004
            • 768
            You can use copper pipe and get a compression fitting from any pluming center, i did this when my lines rust.
            Trading Depot's 404 page. If you've landed here chances are it's because of a broken link. See our homepage at www.tradingdepot.co.uk
            But be ware when I was donne I looked at it and i didnt like it so replaced the whole lot and uprated at the same time!
            Probably the longet S2 project in history EVER!
            • S-Express
              • Nov 2006
              • 1133
              have a look at this how to I did a while back:
              oh and always use quality pipe joiners (like Wade).
                S-Express just the ticket mate! many thanks now to locate a midlands stockist
                • S-Express
                  • Nov 2006
                  • 1133
                  pleasure to be of service, go onto the flowtech website and find yerself a distributor - they're everywhere, have at least 3 near me!
                    Can't find that info on their site however their part of Euro Plumbing who's head office is in birmingham
                      S-Express what part / size was that Wade connector?
                      I've got new lines on the way thanks to Baltiboys2
                      • S-Express
                        • Nov 2006
                        • 1133
                        I used 8mm Cupro nickel brake/fuel pipe and the wade connectors were simply 8mm connectors afaik
                        cheers
