After my recent problem with the MAF and oil residue due to oil fumes being sucked into the MAF/compressor side of the turbo i am beggining to think about the idea of some kind of modification in that area to get rid of that part.
Im not keen on replacing the whole system with a catch tank at the moment.So without understanding much of how the whole system works,would it be possible to block the maf hose from the PCV and instead run a tube from the top to the bottom of the engine and let all the oil fumes out? Or put a filter there to filter them to atmosphere?
Will that effect the PCV system as it is,or does that area that goes to the maf always needs to be under vaccum to suck the oil fumes?
In other words,what is the easiest thing to do to get rid of the hose that goes to the MAF from the pcv system?
thanks
vasilis
thanks
vasilis
