RS2 EM/Turbo on S2
  • MikeLarwood
    • Aug 2008
    • 278
    RS2 EM/Turbo on S2
    Worth it? What else would be required to get it to run?
    Is there any point in the EM? Or are they the same between the two?
    Thanks!
  • shark_90
    • 1475
    You would need injectors, an intercooler, and MAP sensor in the ECU and a set of chips to match as well as the items you listed. And is it worth it? Hell yes!
    1994 Audi S2 Avant - in pieces
    2006 Skoda Octavia vRS 2.0TFSi - goes fast
    1985 Audi 90 quattro - is wet
    Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]
      Won't notice the performance on a K24 but your EGT's will be better and your engine would thank you!
      Also future proofing.
      You can run on stock injectors to about 310 bhp
      • MikeLarwood
        • Aug 2008
        • 278
        So to get to 350-400bhp, what would I need to do? RS2 Crossmember/IC, Injectors and a remap?
        • Rusty
          • 18953
          Full RS2 spec for that, IC & XM, EM, turbo, injectors, ECU upgrade with MRC chips, downpipe (you've got RS2 right?). Clutch is fine as RS2/ABY are the same but if it's old you might want to uprate it.
          • K Simmonds
            • Dec 2007
            • 7627
            You might want to consider a new fuel pump as well if your car has covered a lot of miles on the original pump.
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
            • MikeLarwood
              • Aug 2008
              • 278
              Got the downpipe coming soon, can persuade crossmember and intercooler, exhaust manifold and turbo are available, and the injectors shouldn't be too difficult, right? Anyone linky?
              • MikeLarwood
                • Aug 2008
                • 278
                Fuel pump might be an idea, as I'm going to get all the lines replaced anyway...
                • stevieyid
                  • Apr 2005
                  • 2251
                  Whats involved in getting the fuel lines replace? Mine are starting to corrode a bit underneath so could need replacing
                  • MikeLarwood
                    • Aug 2008
                    • 278
                    Give it to a man down the road from me who's familiar with old Audis along with a load of money and my phone number!
                    • GazzaG60
                      • 4133
                      a pump is needed over 400hp or so.
                      fitting the turbo and manifold stick with the stock s2 intercooler if its aby. injectors will make 320lbsft. depending where the hp is. expect them to run out of fuel around the 300 mark. id say saftey margin 290.
                      fit a better exhaust.
                      personally id say rs2 isn't worth it bang for buck. you can buy garrets and manifolds, injectors and pump and a map and see 400 without any issues.
                      i think under 350hp doesn't really light any fires in these heavy cars.
                        @Mike - consider the Wagner IC - its bigger than RS2 IC, but bolts onto S2 crossmember with a specially designed bracket. Works with S2 or RS2 bumper. The RS2 xmember is a silly price and I consider it to be an unnecessary purchase... You would be much better off spending that money on an RS2 MAF and RS2 airbox - they actually earn their keep.
                        Injectors are easily changed - bit fiddly and you get the odd really TAF one.
                        Let me know if interested in a chipset for RS2 spec - along with MAP upgrade.
                        • DarrenM
                          • Aug 2007
                          • 1227
                          This is true, mine ran 309bhp on the rollers with stocks.
                          • avants2turbo
                            • Feb 2008
                            • 1287
                            whats the price to upgrade the map sensor and chipset to RS2+ spec?
                              GBP250 for zee chipset and ECU tinkering to include fitment of 3bar MAP and such.
                              Search for VMAP to find distributors of those - bout 150 dollars last time I checked - hilarious I know... Been trying to find a cheaper 3bar alternative but no dice so far.
