Oh I'm sooooooh chuffed with myself...
EPROM emulators don't support the turbo chip in AAN/ABY/ADU - well they do if you send megabucks but I had other plans with much more cost effective devices.
I designed and built a little circuit to convert timing from that funky EPROM onto the standard devices. Not rocket science in the big scheme of things, but I worked it all out from 1st principles - knowing how the uP runs a funky muxed bus architecture that I hadn't worked with before.
I ordered the bits and waited - a long time as some dopey things were on back order... Gave me time to research some more and I happened on an old digital cookbook which showed an identical circuit to mine - a good sign or what !
All the bits arrived on Wednesday, wired it up that night (tis a bit agricultiral looking) and buzzed it out last night - dropped in a standard chip this morning (programmed as copy of the funky one that came out)... Cranked up the engine and it started - well it just about started and stumbled and fumbled and just wasn't happy. Had that 'oh ****' moment but its a spare / development ECU.
So I buzz it all out again - everything built as per design - no mistakes, but clearly something is messing up the bus... So I looked at the access times on the standard chip - it was a 200ns device - perfectly good in the 3B ECUs... But tother chip in the ABY ECU was 120ns...
So I find another chip with 120ns timing, plug it in - and its all good. Quick test drive and she's all good.
So frikkin what I hear you all cry ....
1. Proved there is no need to spend buckets of cash on exotic emulators !
2. Gives me real-time emulation of the turbo chip for the first time ever - allowing me to finalise V-Stream and X-Stream chipsets in realtime... and to help me unravel the final mysteries of temperature and altitude correction for boost.
3. Also allowing me to quickly establish new maps with stiffer WG springs and/or alternative WGFVs... You get real tired of changing chips all the time - and erasing and burning and changing, erasing and burning...
4. I might get the circuit cooked up on a proper PCB for others to enjoy. I suspect there is little interest for that on here, but thru some of the generic chiptuner forums I might get some traction... This problem chip gets asked about a LOT on those forums but until now there has been no solution available AFAIK. I might release it thru some of the emulator vendors.
Picture attached of the S2Central 'TCA' (Turbo Chip Adapter)... Its not that big - just had that box available to keep it tucked safely away.
Now just about ready for some long-awaited real-time mapping with a certain monster UrS4 tomorrow... Hope to unravel lots more chip mysteries with this gizmo.
Cost = £20,
Value = priceless
So I find another chip with 120ns timing, plug it in - and its all good. Quick test drive and she's all good.So frikkin what I hear you all cry ....
Cost = £20,
Value = priceless
