Anyone have a solid aluminium bottom pulley ?
  • Matt_D
    • Dec 2004
    • 515
    My damper/balancer pulley is out of shape this one lasted less than 2 years, brand new from audi £330+VAT anyway does anybody have a solid pulley fitted instead ?
    I'm thinking of buying this one from maple racing components:
    Can i ask do you have any problems at all such as the pulley warping/vibrations etc
    '95 ABY Avant - Sold
    '98 B5 S4 -MRC400+ = 464ps 741nm
    I think Terrybullwon and others on here are using the Maple racing one
    • Rusty
      • 18953
      VolcanoRS had some steel one made up for <£100 IIRC.
        Not anymore, he's selling it
        • volcano rs
          • Jun 2005
          • 2265
          i have alumimium pully on mine and i have 3 steel crank sprockets for sale
          • Puglife
            • Jun 2006
            • 731
            correction, he was.... its sold
            Jay - pug_life85@hotmail.com
            1986 Audi UR quattro - WORK IN PROGRESS
            1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
            • Matt_D
              • Dec 2004
              • 515
              Do you have any problems with it ?
              • jade
                • Jan 2005
                • 1811
                I have same problem "wobbly dampner", after a chat with Aelred i decided to go with the OME dampner again, As it dampen's the stress loading on the crank & helps to make the car run smoother.
                RS 2 580HP
                • volcano rs
                  • Jun 2005
                  • 2265
                  i've lightened my crank flywheel and i have aluminium pully .i get a little vibration on load at low reves ,other than that no problems the engine spins up a lot faster
                    Maple Racing Components
                    I've asked Paul in MRC to make up an ABY pulley as the ones he'd been making and shipping were for a 3B with v shaped belts instead of the ribbed shaped belts.
                    He should have it ready to ship soon?
                    HTH
                      @ Volcano
                      Can you remember if you have the opportunity to have the crank, flywheel, and pulley balanced as a set or was the pulley just a replacement for the OEM one and the engine was still in the car?
                      Thanks.
                      • volcano rs
                        • Jun 2005
                        • 2265
                        Thanks.
                        the crank ,clutch plate, front pully, and flywheel were balanced together .rods and pistons were still in the engine so he calculated the weight of those items then balanced everything
                          Grand,
                          Thanks for the feedback.
                          Kind regards.
