i have just removed a "super chips" chip to fit a "pair" of mrc hi boost chips on a 3b s2, i have set the wastegate back to where i concider it to be correct (super chips chip relied on tightening the spring from what i can make out)
just wanna make sure im in the right place
i am talking about guage readings below
may be a silly question but the mrc chips are a 1.3bar map
does this mean they hold 1.3bar or peak 1.3bar (19psi)
what pressure are people seeing with mrc chips on an 3b s2?
i think im not quite right on the waste gate as i retested with super chip after winding screw out to cover the " un tarnished " threads and i saw 9-10psi and holding quite well, i was lead to believe stock pressure is 0.5 bar /7psi
so i could be 3 psi out or i could be a percentage out
