hmm, still no start up
  • AUDIS2avant
    • Jan 2009
    • 670
    • Country: Denmark
    Well not 100%, have my back seats up and can hear something buzzing in the back when crancking, and yea the afterrun pump is also running as you say.
    think i´m gonna test for power to the pump tomorrow.
    But i still cant find out why the coils wont fire
      Have you lifted off the camshaft cover with plugs attached - then earthed to check for sparks - are you sure there is no spark.
      Could you (or someone) have messed with the connections on the POS units for example - that would skew things off big time.
      • pixsaudisex2
        • Sep 2004
        • 3110
        Originally posted by S2central.net
        Are you REALLY hearing the fuel pump running ?
        There is a few seconds 'whirring noise' when you 1st turn ignition key ON - this is often thought to be the fuel pump being 'primed' - thats what you get on K-Jetronic dinoasaurs but not Motronic... That noise is actually the afterrun water pump getting tested by the ECU before the engine is started.
        If you don't have a voltage tester, then wire up a low wattage 12V bulb (like 5W sidelight) across the terminals of the fuel pump wires to make sure it gets lit up when cranking.
        I thought the fuel pump ran as well before startn up.... is this not the case.
          Tis a myth...
          It only occurs on K-Jetronic so as to prime some fuel into the accumulator for its continuous injection system - makes for easier starting on that setup.
            #20
            If you want proof - have a friend turn the key to ignition while you have your hand on the afterrun pump !
            • Knight Rider S4
              • 3541
              Originally posted by AUDIS2avant
              Sparkplugs get wet but cant se a spark from any of the 5 cyl?
              No problem with the pump as the there is fuel going to the injectors
              I will stick with the Ignition switch
              93 S2 Avant Parting
              91 URQ RR
              02 A4 tdi Avant
                #22
                It could be the ignition switch - but its a bit odd if the pump is getting power when the ECU and/or coils aren't.
                Oh here's a silly question - what spark plugs are fitted - stock items or something funky ?
                Half a day with a breakout box, oscilloscope and VAGCOM would root cause this one !
                • AUDIS2avant
                  • Jan 2009
                  • 670
                  • Country: Denmark
                  #23
                  Standard plugs nipondenso ones.
                  Have just checked, there is fuel going to the rail so pump is working.
                  It also gets 5 volts to the sensors when i cranck the engine.
                  Have also tried some other spark plugs.
                  Still no spark tho hmm
                  • Jas11n
                    • 5067
                    Standard plugs are Bosch F5DP0R.
                    2001 Avus Silver B5 RS4.
                    1995 S2 Coupe - sold (sniff)
                    • AUDIS2avant
                      • Jan 2009
                      • 670
                      • Country: Denmark
                      #25
                      I couldent get those so i got the denso´s as they are the same as the bosch ones.
                      Denso´s are called pk22pr8
                      And they have worked fine for the last 5k km have even tried other plugs, but no luck
                        #26
                        Never mind so much having 5V supply to the camshaft sensor - you need a pulse from it every camshaft revolution. Use a simple LED style 5V tester... The light will stay on then momentarily blink off.
                        Pretty sure you replaced it already though - check the ring on the back of cam sprocket is not damaged and that the wiring between sensor and ECU is all good. I can give you a pinout if necessary.
                        • AUDIS2avant
                          • Jan 2009
                          • 670
                          • Country: Denmark
                          #27
                          I checked the ring as it was wery dirty and i cleaned it up.
                          Would be nice to have a pin out from the sensors tho, as i have an idea that it´s a bad conection.
                          The hall sensor, should it send 5v out and 0v when it hits the "hole" in the cam wheel?
                          Cranck sensor i have 3 to test with, and have done just that, and nothing
                            What about the flywheel pin?
                            • AUDIS2avant
                              • Jan 2009
                              • 670
                              • Country: Denmark
                              #29
                              Back again.
                              Flywheel pin is present, timing is ok and have done a output test on the wires to the coils and power is coming out, they are just not firing????
                              Found the test on http://www.s2-audi.co.uk/work_shop.htm
                              Just cant understand why the coils wont fire....
                              • AUDIS2avant
                                • Jan 2009
                                • 670
                                • Country: Denmark
                                #30
                                tonight after almost having the whole engine apart, it fired up, now also with pauls chips inside
                                I have to say big thanx to everybody for your help, specially paul for the tecnicaly part and urs4boy also.
                                Now i have a full insight of the engine so if anybody wants help???
                                Fault was a combination of bad ground on the plenum, dirty connectors and dead cranck sensor and mfts.
                                It startet 7times in total when cold up to hot, just to check so have to se tomorrow after a full night without tuching it tho, so wish me luck
                                Am looking forward to driving it now, cause the short trip i took for testing, it was compleetly transformed powerwise
                                So thanx again guys, this is what the forum is all about
