hmm, still no start up
  • AUDIS2avant
    • Jan 2009
    • 670
    • Country: Denmark
    hi guys.
    Have changed the fuel pump relay, cranck sensor, hall sensor and the mfts sensor today, and the car still wont start.
    I´m getting no fault codes, so am ******** my self here.
    Sparkplugs get wet but cant se a spark from any of the 5 cyl?
    Any ideas?
  • GT500
    • Jun 2006
    • 2181
    Motor fuses in the fuse box under the bonnet. If a coil fails it blows the fuse.. no start.
    Rob..
    87 UR 20v ABY
    97 S6 Avant
    • AUDIS2avant
      • Jan 2009
      • 670
      • Country: Denmark
      Thanx m8.
      Just checked all fuses and all ok.
      I´m getting no spark what so ever, but suddenly when i was clening up i had taken the coils up and put 5 spark plugs in the coils, nr1 coil and the wgfv startet to go nuts and valve clicked constantly and nr 1 coil started to fire????
      Maybe my ecu is dead then?
        Have you checked earths ?
        • AUDIS2avant
          • Jan 2009
          • 670
          • Country: Denmark
          Yes, earth wire on manifold and on top to coils are good and working
            Do you have VAGCOM ?
            Have you tried doing output tests yet - thats a good indication that ECU is basically sane and can communicate some outputs.
            You really need an oscilliscope to test if the ECU is receiving the right signals - and that it is trying to send primary voltage to the POS.
            With an LED tester you can verify presence of pulses at G40 and the injectors but it tells you so little compared to a 'scope.
            There's honestly not that many things which will cause a no-start. The really tricky ones are fractures in the wiring loom and/or bad contacts - you need a breakout box and lots of patience in those situations. Even if you have to hire a scope it would be worthwhile...
            • AUDIS2avant
              • Jan 2009
              • 670
              • Country: Denmark
              I do have on sunday?
              Can i make it trigger the coils and injectors? just so i can se the wire´s are ok?
              I need a 5v led tester really, but am getting 5v to the hall sensor so guess that is ok then.
              • Knight Rider S4
                • 3541
                Does there look like there has been water in the fusebox or a water leak down beside the passengers footwell? as with all these different things getting power would indicate something is giving a live feed to them (as in shorting out )
                93 S2 Avant Parting
                91 URQ RR
                02 A4 tdi Avant
                • AUDIS2avant
                  • Jan 2009
                  • 670
                  • Country: Denmark
                  Hmm nothing from engine side, but my front window has been leaking a bit in the left side but the water did only reach the seat (dripping) but can it go up to the fuses from the back???
                  Wouldent it blow a fuse or somat?
                    Your left side is drivers side - thats where the auxiliary fusebox is - check it out for nice clean and dry contacts... Hopefully water hasn't made it into the loom.
                    With VAGCOM you run the output tests and it covers WGFV, EVAP, ISV and the injectors - not in that order... The tests are sequenced by opening / closing the throttle when prompted on screen.
                    • Knight Rider S4
                      • 3541
                      HAve just read through all your posts and other threads and trying to see some sort of pattern
                      Need to answer some questions
                      When the WGFV started clicking and the Number 1 coil fired was this with the ignition switched on ?
                      What immobiliser is fitted to the car?
                      When did the problem start exactly ?
                      Have you checked the ignition switch?
                      You say the problem is temperature related ..are you sure?
                      93 S2 Avant Parting
                      91 URQ RR
                      02 A4 tdi Avant
                      • AUDIS2avant
                        • Jan 2009
                        • 670
                        • Country: Denmark
                        When the WGFV started clicking and the Number 1 coil fired was this with the ignition switched on ? Yes ignition was on
                        What immobiliser is fitted to the car?None
                        When did the problem start exactly ?Some time ago now, and got worse and worse until now
                        Have you checked the ignition switch?You mean for the key?
                        You say the problem is temperature related ..are you sure?It looked like it before, as the car dident want to start when it was below 0 deg
                        Have tried to answer in your quote
                        • Knight Rider S4
                          • 3541
                          Ignition switch at the back of the barrel were the key inputs...As you say the problem has got worse this is a classic trend for ignition switch fault as the internals of the switch break down causing loads of faults which are not picked up by vag.com
                          Change the switch would be my first bet !!
                          93 S2 Avant Parting
                          91 URQ RR
                          02 A4 tdi Avant
                          • AUDIS2avant
                            • Jan 2009
                            • 670
                            • Country: Denmark
                            Hmm does this not cut the power to the box only??
                            As i can hear the fuel pump running when i cranck the car?
                              Are you REALLY hearing the fuel pump running ?
                              There is a few seconds 'whirring noise' when you 1st turn ignition key ON - this is often thought to be the fuel pump being 'primed' - thats what you get on K-Jetronic dinoasaurs but not Motronic... That noise is actually the afterrun water pump getting tested by the ECU before the engine is started.
                              If you don't have a voltage tester, then wire up a low wattage 12V bulb (like 5W sidelight) across the terminals of the fuel pump wires to make sure it gets lit up when cranking.
