Hello, I have a question. Is a Motronic ECU from a AAN compatible with a ABY engine, for example? I know that the pressure sensor is the same, but the software inside the turbo and injection chip are different? And a Motronic ECU from a AAN or ABY with a ADU engine? I know that the pressure sensor is different and also the software inside the turbo and injection chip, but if I change this parts can I put a ABY or AAN Motronic on a ADU engine? And a ADU Motronic on a ABY engine? If I change the chip?
Thanks a lot! Bye
Alessio
Thanks a lot! Bye
Alessio
