has anyone bought a manifold from this guy?
  • s2 on the way
    • Jul 2004
    • 220
    I've been browsing ebay.co.uk and ebay.de for a cheaper manifold as I really need one to replace my stock aan mani as it cracked, not to mention it being super weak in design.
    I"ve seen a few "rs2" manifolds for sale. I"m thinking someone copied the mould and there are now duplicates. Any thouhts on quality?
    anyone runnig one?
    http://cgi.ebay.co.uk/RS2-AUDI-TURBO...1%7C240%3A1318
    thanks,
    dustin
  • Knight Rider S4
    • 3541
    Yeah I have bought the same one ...
    This one
    A few issues I had with it which were easy fixed ..Holes were not properly drilled (mob pics)
    The studs they had with the manifold for the WG were the wrong thread so replaced them
    But apart from that all ok
    Fitted
    Steve
    Only a few issues
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • Rusty
      • 18953
      Is this the STR manifold or an RS2 copy?
      • s2 on the way
        • Jul 2004
        • 220
        it appears to be an exact duplicate of the rs2 mani....
        how long have you been running it steve? no cracks yet I presume?
        thanks for the infos
        • Anagonda
          • Aug 2005
          • 70
          Note that the wg stud holes aren't at correct place. You need to enlarge the manifolds wg hole a bit to get it to line up with the wg.
          • Knight Rider S4
            • 3541
            I have only just put it on so cant comment on the cracks yet
            With regard the WG after i changed the studs over it fitted fine
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
            • s2 on the way
              • Jul 2004
              • 220
              that sucks about the clutch and the taking out of the motor again....lets just say I know the feeling as I'm right there with ya....
              I painted my bay for a colorchange and that really sucks.........
              yours looks mighty nice
              • Knight Rider S4
                • 3541
                Yeah taking the engine out was not good but have it sussed now I can get engine out in 2.5hr..New clutch and flywhel set up coming tomorrrow hopefully so looking forward to seeing as the spec is something I have never seen ..Kevlar plate which mates to flywheel through a rough surface flywheel and the friction between the two creates the face and hardens the kelvar pads like marble
                93 S2 Avant Parting
                91 URQ RR
                02 A4 tdi Avant
                • bikerjim
                  • Feb 2008
                  • 1028
                  How are things with this manifold now you have run it for a while?
                  • s2 on the way
                    • Jul 2004
                    • 220
                    I have to say, for the money it is decent.....
                    only problems is the machining on the bottom next to the flange to fit the nuts in there. mine was a little thin and in the process of cleaing up the bores a little bit, I went right through it. But that is because of my dumb *** not noticing how thin it already was there, but we arc welded it and she's been great. not all that many miles on her though...
                    • Knight Rider S4
                      • 3541
                      No problems yet touch wood ...and i have pushed it ...was glowing a couple of weeks ago
                      93 S2 Avant Parting
                      91 URQ RR
                      02 A4 tdi Avant
