Right, any model numbers and details? Approximate costs?
I5 GT Turbos 2871 / 3071 / 3076 / 3082 / 3582
I did create this thread to specifically talk about the Garrett turbos and colate information about them into one thread.
I have seen that a lot of people keep trying to divert away from garretts to other turbos, i'll happily create one for discussions of those turbo if required.Comment
im sorry Jamo,
did i ask something irrelevant with the garrett turbos??
If that comment was intended to me,please let me know. I think i specifically asked something ABOUT these turbos so that i would know how they compare to others.
if this commend was NOT intended to me,then it's timing of post is wrong IMHOComment
1994 80E Avant
1986 2L Golf 2 on AlcoholComment
Good call, perhaps an 'Alternatives' thread to discuss alternative turbos other than the G's. However, stating what other turbos are comparable and leaving it there would be useful in the context of this thread, or in a 'Comparisons' thread.Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
Garrett turbo FAQ page
My initial K26-GT3071R 0.63AR results for the current engine/clutch setup. Will post new info once I continue upgrading my Avant
ECU is not yet mapped to full potential of the turbo.
Max boost is 1.7 bar at 3000 RPM till redline. Need bigger IC, stronger clutch and one day a ported cylinder head.Attached FilesComment
That's a really strong plot with fast spool. Shows how strong these turbos pull on the S2.
The same boost on an RS2 would be a lot less so that leads me onto the next question-
What sort of boost can you run on stock rods with a 3071?Cheers'en, AndyC
