@4WheelDrifter Sorry, I didn't say thank you for getting the part number.
@Jon441cc I am still running the standard ignition, but everything is new OEM and much of my wiring has also been replaced to reduce resistance.
@S2Central.net I have made sure that it's the correct tip on the arm. The only thing extra that I've considered was an SQ dizzy, but is that a direct replacement?
Good news, the local stealer has an S3 DV in stock!
It'd be good if I could get a whole month out of one. This will be my third in a month. I've tried the Forge 007, but that broke too. Do you not think the APR R1 would be up to it? Which model would you choose, if looking at long term cost efficiency, rather than regularly changing a much cheaper 710N? If I just go through one 710N a month, it would make sense to spend £200+ on a better diverter if it'd be up to the job.
I would like DI, but that's a whole lot more money needing to be spent, plus another remap. I've got about a grand that I can spend, but then I'm done. On the list of things I'd still like to do is:
* DI (but staying with Motronic, as I want to keep A/C)
* Interior retrim, including new carpet
* Carputer build
I do have berely used Konis that I plan to sell to top up my funds, but I still think that I'll only be able to do one item on the list, not including DI. I may have to consider selling my refurbished S8 wheels and winter tyres, as they were only on for two weeks this year (and not the snowy period either
New seats and a roll cage will come when it's retired to the weekend for track use.
* Carputer build
).New seats and a roll cage will come when it's retired to the weekend for track use.
