I've attached a few pictures to demonstrate, but while I was bolting on the starter motor I found a wire with apurple 2-pin female connection. It runs along the lower PCV pipe.
After a good look on the left-hand side of the engine bay I found what i think is the corresponding plug, on the gearbox. Can anyone confirm that this is where it should go?
Cheers!
Ross
Cheers!
Ross
Didn't see that thread before! Could have been worth replacing that switch while the engine was out then.. ah well fingers crossed.
