Hi,
I've just finished giving my URS4 (1993 / K) a full service, filters, oil change, plugs, discs, pads, shock, springs, flexi's, back caliper, handbrake cable, and the reason why it went in the garage in the first place the bloody clutch master cylinder & peddle box bracket (cracked!!), anyway got it all fixed and was feeling pretty good about it.
Took the car out the garage and drove about 8 miles with some hard braking to try and bed the new brakes in, then took it home and parked it up. Went out the next morning and it won't start...........turning over but nothing.........won't bump at all.
Took it back to the garage, started checking things;
Fuel Pressure - Fine
Fuses / Relays - Fine
No loose wires, that I can see
NO SPARK - I wonder if this is to do with the immoblizer, when I took off the panel under the dash, the immoblizer was just hanging under there and I thought it didn't look like something Audi would have just left like that......and I don't know if its standard or aftermarket........?........does someone know or could check.....?
The immobilizer is a;
Conlog WASO XPi it has a sticker on the side with a hand written number on it - 18207 it also has the telephone no. 0203 352222 (old number so add a 1 after the first 0), I have a chip key which slots in the dash and that blinks if the chip isn't inserted, after I insert the chip it stops blinking which I assume means the immobilizer is de-activated.
Anybody had this bother before, or for that matter able to come up some suggestions to whether or not its the immobilzer or something else........All suggestions, previous experience, comments welcome!
Thanks
Leigh
Thanks
Leigh
