hey seen this...
Chip Tuning Package 3B, Stage 1 $720.00
Click to enlarge
Click to enlarge
Suitable for all 3B, stock turbo Audis. Requires a specially notched 3.0 BAR MAP sensor for the 3B ECU, included in the kit. Uses stock FPR and wastegate spring.
We recommend this tune for all motors with stock internals, upgraded engine rods or pistons not required.
Specifications:
-20psi overboost, 13psi to redline, 7000rpm rev limiter
-Air/Fuel ratio 11.5-11.8 under boost, 14.7 under light load and idle conditions. Recommended for 91-93 octane fuel.
-~40whp increase over stock power, and a much broader powerband.
Chip Tuning Package includes:
- Specially notched 3.0 BAR VMAP sensor with installation accesories for 3B ECU
- 034EFI Stage 1 Chipset (fuel/timing and boost)
Note - If your ECU is already socketed, then we can ship you the Chip Tuning Package to easily install yourself with included instructions. If your ECU has not been socketed, you'll need to arrange to ship your ECU to us, we can turn in around in 24hours and back to you quickly.
To obtain a shipping estimate for this item please Log On
Available Options:
Remove 3.0 Vmap: (-$175.00)
Click to enlarge
Click to enlarge
Specifications:
Available Options:
