for 3b owners.......
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    hey seen this...
    Chip Tuning Package 3B, Stage 1 $720.00
    Click to enlarge
    Click to enlarge
    Suitable for all 3B, stock turbo Audis. Requires a specially notched 3.0 BAR MAP sensor for the 3B ECU, included in the kit. Uses stock FPR and wastegate spring.
    We recommend this tune for all motors with stock internals, upgraded engine rods or pistons not required.
    Specifications:
    -20psi overboost, 13psi to redline, 7000rpm rev limiter
    -Air/Fuel ratio 11.5-11.8 under boost, 14.7 under light load and idle conditions. Recommended for 91-93 octane fuel.
    -~40whp increase over stock power, and a much broader powerband.
    Chip Tuning Package includes:
    - Specially notched 3.0 BAR VMAP sensor with installation accesories for 3B ECU
    - 034EFI Stage 1 Chipset (fuel/timing and boost)
    Note - If your ECU is already socketed, then we can ship you the Chip Tuning Package to easily install yourself with included instructions. If your ECU has not been socketed, you'll need to arrange to ship your ECU to us, we can turn in around in 24hours and back to you quickly.
    To obtain a shipping estimate for this item please Log On
    Available Options:
    Remove 3.0 Vmap: (-$175.00)
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
    Thats a big price... almost GBP500 at current rates. In a month or so I should be doing 3B chipsets including a 2.5bar MAP upgrade (the stock turbo can't go more than 1.5bar boost usefully) for half of that.
    For a bit more they'll have three maps / modes as well that can be switched on the fly with two external switches. Watch this space.
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      PAUL, may with 300kpa map sensor and all stocl mechanicals will go to 1´7bar only in 5th gear,1´6bar in 4th gear and 1´5bar in third...
      i think that it will be reliable, i meet some people with this similar setup and never had any problems with the turbocharger ,because the 1´7bar only appear in few time under full acceleration and early go lossing pressure
      great to see you making 3b ECu setups
        I think its too high for K24 - it becomes a hot air pump with very low efficiency at these levels. You might get away with it using very large intercooler - but its a lot of stress on that little turbo !
        • CoCaine
          • May 2008
          • 216
          • Home: Romania Current: Spain
          Hi Paul.Do you make chips for 3b with some upgrade?Turbo,EM,RS2 injectors,3" exhaust,bigger IC etc?
          Cheers,
          Costan.
          • 20vQC
            • Aug 2007
            • 684
            • Current: Italy
            Racco!! Que ha pasao contigo tio??? Como va eso del motor que tuviste varios problemas la ultima vez??? Oye yo me deshice de mi coche
            Rocco!!! What happened to you?? HOw's you engine doing???
            - Looking for a S2
            - Lancia Dedra HF turbo i.e. (4sale)
            - Typ89 Coupè quattro, 20Vt AAN, VEMS, K24-7000@1.3bar (scrapped )
              Cheers,
              Costan.
              I'm working on that - maybe this Summer - probably look at RS2 and 2871R setup.
