3B Tensioner
  • Doug_RS2
    • 3847
    3B Tensioner
    How do you remove a 3B tensioner? Some sort of puller? I need some bodge ideas!
  • s2driveruk
    • 12696
    steveH will know cos i was trying to blag his when we were at Gregs' meet and my belts were being changed if you remember....
    Cheers,
    david
    1992 3b S2 Coupe
    • SteveH
      • 4460
      Doug, the tensioner has a small protruding round lug on the rear side. This locates into the oil pump housing. It's a tight fit, so you may need to give it a little tap with a rubber mallet to get it to move. Don't try to get it back into place using the bolt that secures it. This is likely to snap or strip it's threads in the process. Just tap it back in gently using a socket on the centre surface.
      I'll go out to the garage and take a pic of it...
      91 Modded 3B
      14 A6 Avant Black Edition
      • SteveH
        • 4460
        Here u go...
        91 Modded 3B
        • SteveH
          • 4460
          About 5mm of the tensioner fits into the oil pump housing
          91 Modded 3B
          • Doug_RS2
            • 3847
            Steve - I need to get one off the car before I put the new one on .
            • SteveH
              • 4460
              If you have a new one, don't worry about damaging the old one getting it out.
              Lever if from both sides at the same time and it will pop out. The one in the pic was fitted to the pump 20 mins ago. i just tapped it from side to side gently with a hard rubber mallet and it came out OK. There's plenty of material around it, so you shouldn't need to worry about damaging the oil pump housing.
              91 Modded 3B
              • Doug_RS2
                • 3847
                OK - thanks - it does have an M10 thread for pulling - I will hammer it out though!
