Hello friends, I have already search in the forum but I have not find all the information that I need, I hope to find it here, thanks a lot for your patience.
My RS2 have a problem and I don't understand what can cause it, the problem that I have is the 00561 error code, the car is completely original, only I have remove the cat and I have mount PKM chips for 370 hp, I remember that also with the original Motronic chips for 315 hp and the original cat I had 00561 error code and also another error code that now I don't remember exactly which was but I think was 00537. With this two error code and the original chips the car had not problems on the road, now with the PKM chips for 370 hp I read only 00561 error code but the car have problems on the road, when overboost turn on I have a bit on knock and the engine for me I think that is slow in acceleration, when the engine is hot at the idle I have the impression that sometimes there is a ignition failure in one of the 5 cylinders, is really a very small ignition failure that can be also normal, I don't know. I have already change some parts and I have not resolve the knock problem and the ignition failure problem if really there is a ignition failure problem and isn't just my impression, when the engine is cold, immediately after turn on it I have also a leak in the exhaust manifold I think but after one or two minutes I have not this problem. I have mount a new lambda sonde original from Bosch with the correct code for the RS2, new and original Audi MAF, new and original Audi N75, new and original Audi pop off valve, new and original Audi Druckregelventil an der Kurbelgehäuseentlüftung, I don't know the correct name in english, spark plugs are original Bosch F5PD0R and have about 10000 Km, also the connectors from reels to spark plugs have about 10000 Km, I have change also the fuel filter with a original Audi too and also the FPR that was a original Bosch 3,8 bar FPR for ADU engine with a 4 bar FPR for ABY engine. Now I want check the air inlet temperature sensor in the air inlet manifold and the water temperature sensor in the back of the engine but I don't know how test this parts and the correct value that have. I want make also a boost pressure test with the original chips for find any boost leak and make a pressure test of all hoses, but I don't know the values of the boost pressure on a standard RS2 normally and in overboost, so I need this values and if possible also the value of the fuel pressure because I want check also it but I don't know where and how check it, can I check also the injectors or not? Which other parts can cause my problems? Thanks a lot!
Bye
Alessio
Bye
Alessio
so we know it is not due to only a knackered lambda sensor
