Hi. i own a 95 RS2 with mtm Stage 1 chip. Installed a boost gauge 2 weeks ago and that peaked 1.6/65 in 2.gear and 1.7 in 3, 4 & 5.gear.
Today i changed all the vacum lines and installed a Forge replice bypass valve but i was unsure on what spring i should use (came with 3 different) so being a man
i put the stiffest in and mounted it and all looks good.
Then for the Testdrive.... i do get boost a bit earlier then before. But it wont go over 1.5 in 2.gear and it sometimes peaks to 1.6 in the remaing gears.. But i now i've got the good sound when u go of the throttle, not the ricerocket pppsssssssjjjjjj but the one one thats sounds like friggin bird
but that tells me that the spring might be a bit stiff for the car cause isnt that the sound when the bypass doesn't open and the air goes back to the turbo? or am i wrong?
Anyways, would this stiff spring cause a lower boostpreasure?
i put the stiffest in and mounted it and all looks good.Then for the Testdrive.... i do get boost a bit earlier then before. But it wont go over 1.5 in 2.gear and it sometimes peaks to 1.6 in the remaing gears.. But i now i've got the good sound when u go of the throttle, not the ricerocket pppsssssssjjjjjj but the one one thats sounds like friggin bird
but that tells me that the spring might be a bit stiff for the car cause isnt that the sound when the bypass doesn't open and the air goes back to the turbo? or am i wrong?Anyways, would this stiff spring cause a lower boostpreasure?
Im tired
