My clean engine!
  • Dr H
    • 1175
    My clean engine!
    Think it looks quite good really pity it wont look like this after I've torched the car see my post re boost leak.
    Ex 1994 Avant - now driving a Lotus 340r
  • Sidspud
    • 1223
    • Home: Scotland Current: United Nations
    Nice.
    ex '93 Avant owner
    • S2 Ant
      • 3682
      Looks very good!
      Ant
      2011 Kawasaki Z1000
        Gorgeous! Don't torch it! :-)
        • jubjub
          • Nov 2003
          • 1239
          Looking slick, Leigh BTW were did you get that 8mm hose from in the end?
          • horvathg
            • Dec 2003
            • 556
            Leigh, its so clean you could eat on it.....and your samcos look good too.
            Gabor
            96 ABY coupe full except sunroof. With Porsche big red brakes, remapped ECU, xenon lights, RS2 MAF
            • Dr H
              • 1175
              Yeah look sgreat but it's already showing a few problems I painted it with Halfords VHT Aluminium paint. Looks superb and has a nice matt finish. Trouble is it marks incredibly easy just putting everything back together put marks all over it.
              I'm not sure it's curing properly either as the paint is rated up to 450 c and I don't think it's getting hot enough. I really hope I don't end up taking it off and doing it all again
              At least it started first time when i put it all back together
              I got the 8mm hose from a local motor factors place. Just standard hose (in fact I think it was actually fuel rated stuff) £1.10 per foot. Hopefully it will work OK. I'll wait and see.
              • APNess
                • 479
                Looks great Leigh - I'm gonna carry on with some half assed polishing with mine with the bits still on the car, but will no doubt in the end get it powdered coated etc. Still look like ***** with all the tin foil all over that black pipe, but what the hey - when everything else is too hot to touch that inlet pipe is only warm, so it's doing something right. I'll have to get off my *** and cut up that polished stainless I got for heatshielding, and hack some holes in the bonnet. Just another job to 'get round to' but yours looks fab - better than new!
                'The Bacofoil Express'...
                No more.
                Leon TDI 150 run in now.
                Very slow.
                Needs a chip.
                • jameswkr
                  • 538
                  Dr H. Your wastegate pre load looks like its been played with. Are you sure this is set correctly ??
                  • curlyks2
                    • 1069
                    Looks sweet
                    Ck.
                    PS Blast. "Clean Engine" just added to list of things to do. That list just isn't getting any shorter.
                    Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
                    • Ski
                      • 2591
                      all u need now is to clean that yellow cap
                      ABY Coupe
                      • andre
                        • 65
                        • Country: South Africa
                        Yeah, good point there. I have spent the better part of 6 months trying to find a "leak" that was not there. In the end a good chap with a VAGCOM and some turbo knowledge diagnosed the wastegate "preload" as having been fiddled with. He returned it to factory spec and the difference in performance and drivability is remarkable. I'm not sure how it all works, but the chappie worked on the hex screw in the top of the wastegate and that's it. Worth a check if you can't find your "leak"
                        1995 RS2 Avant - Custom SS exhaust, Koni adjustables, Custom map, large grin ...
                        • Dr H
                          • 1175
                          Git You're dead right - but still a git for pointing it out
                          • audiman
                            • 4827
                            Wind that WG spring down!!! Thats the way
                            Tom C - www.rcmr.co.uk
                            Audi UR Quattro
                            Audi 100 C3 2.0 5 cyl 115ps
                            Audi B5 RS4 645ps 911nm
