If you have the ABY N-Stream then you'll feel a difference going to V-Stream... More aggressive delivery and a bit more oomf up top - still not dyno'd yet. Running that with a RS2 airbox and RS2 intercooler is going to be getting very close to 300bhp... But you'll not get 'RS2 power' without an RS2 turbo - you canny change the laws of physics etc etc
There is no need for uprated rods with N or V stream... Obviously it is better to do that - but big money as you know. Max boost on V stream should be in 500Nm territory so safe for RS2 rods.
The intent is to make them plug and play... will probably have to err on side of rich to accomodate for variance in MAFs and such.
AFR shouldn't be necessary, but having one fitted does give you that confidence that all is well - though they can be a bit distracting on daily use. If you fit one bigger injectors then I could probably do some custom work to get the best out of your RS2 setup with even higher boost levels and the uprated rods you have - IIRC...
Sounds great, i have to re think my engine project now as i may as well start with the RS2 turbo :mischeif:
Out of interest how far away are these from the limit? i.e. if one were to go the tradition custom map route for a car with rods what kind of figures for boost and torque would we be talking about?
Cheers,
Mark.
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
can i just ask is the 4 bar fuel pressure regulator 100% needed to do the N Stream homefry? I have everything else except the fuel pressure reg as i am not aware first what it is and secondly that i needed it for the upgrade
3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
I run an S2 MAF with on mesh at all! There is a debate about whether the mesh stabilises the flow but I've not noticed any running issues in 3 years...
