Fuel Filter
  • BlackBullet
    • 146
    • Country: Brazil
    Fuel Filter
    Hello Everybody,
    Today something occurs.
    I stopped the car at garage, and 10min latter, I decided to go out again.
    So, I try to turn it on, but doesn´t works!
    I am looking for the filters, as air filter, fuel filter and the other here at Brasil. This is not so easy to take.
    I have disassembled the air box, and try to turn the car on without air filter (this air filter need to be replaced, but I still looking one for it.),and nothing different.
    Than, my next step, will be the fuel pump. Because that noise that it make when your engine is on, I do not remember if it does.
    I know that it is located near the rear right wheel, but where?
    It is an external pump???? or it is located into the fuel tank?
    So, about 20min passed and I try to turn it on again, and it works... How can it do???
    Later, my suspection is the fuel filter... Because if it was a original part, may have 10 years ... And can obstruct the fuel flows.
    My question is... where is this fuel filter and the fuel pump????
    Thank´s lot!
    Rafael Pinto
    Audi S2 1994/1995 Avant - Black
    Audi RS2 1994/1995 - Black
  • GandalfS6
    • 332
    • Country: South Africa
    If you have a Coupe, there are instructions on changing a fuel filter and photos in this thread http://www.s2forum.com/forum/showthread.php?t=3191 If you have an Avant it is much more difficult but search the forum - I did see a few threads about that.
    The fuel pump is located in the fuel tank - also try the search function.
    1995 Silver S2 (ADU) Coupe
    2006 Porsche 997 Carrera S
    2006 Misano Red RS4
    2004 VW Touareg V8
    2007 Golf Mk1 Race Car
    2004 Mercedes Benz Vito 112CD
    • Doug_RS2
      • 3847
      A common problem with those symtpons is the Cam sensor is about to stop working - the heat of the car means it won't start - You could try pouring sopay water down the back of the cam cover to see if it helps - but you will more than likely need it replaced very soon.
      I've been stuck in a petrol station for 30minutes when it happened!
        Have to agree with Doug on this as a likely cause - not uncommon...
        • BlackBullet
          • 146
          • Country: Brazil
          OK.. but where is located this cam sensor?
          Anyone have a diagram to ilustrate?
          Thanks,
          Rafael Pinto
          • Lee
            • 1512
            After a similar problem, I am now discounting the security system! I sometimes hear the fuel pump immediately before cranking, when I do it starts. Sometimes I hear it more faintly and then it doesn't start...my problem is linked directly to the fuel pump. I will replace it with a Bosch motorsport item to see if my fault is cured.
            Designun Limited....
            • Stick Insect
              • Dec 2003
              • 2338
              Lee the neighbours audi 80 had a whirring noise when the fuel should have been pumping but it wasn't. It was the pump just had weakened terribly. The fuel pump relay was very ill as well.
              Nasty to trace the fault!
              David
              • BlackBullet
                • 146
                • Country: Brazil
                Hey folks,
                The car have the same problem today, and i really need to know where is located the cam sensor.
                Any one can help me?
                Thanks,
                Rafael Pinto
                  Originally posted by BlackBullet
                  Hey folks,
                  Thanks,
                  Its located behind the camshaft pulley on the ABY (ADU or late AAN) engine.
                  • BlackBullet
                    • 146
                    • Country: Brazil
                    ok, i understood...
                    can you take a foto?
                    The car is in downtown, and i need to go there to take it out.
                    Thanks,
                    Rafael Pinto
                      Been looking for an image in the on-line family album, but with no joy - I hate that Russian website sometimes... Maybe the parts boys can find a pic for you...
                      • s2avant
                        • 2426
                        The standalone version is not much better for showing this. Heres the only pic I could find of it in the family album:
                        I've highlighted it blue.
                        HTH
                        Ben
                        • BlackBullet
                          • 146
                          • Country: Brazil
                          Hey friends,
                          I found the problem...
                          The problem wasn´t the cam sensor, neither the fuel pump nor the fuel filter.
                          It was an electrical problem, the wires that energize the 5 fuel injectors have broken the plug, than without contact, no injector...
                          Reguards,
                          Rafael Pinto
